Howard rotovator disassembly
Brian
04-15-2000 16:11:21
I am in the process of resealing my rotovator. The side cover is removed, now I need to get the shaft out of the bearing & seal. It appears that once you unbolt the other side it should slide out but it doesn't. Any words of advice? Is silicone adequate for the side cover. Thanks
Paul Fox
04-15-2000 17:32:25
 Re: Howard rotovator disassembly in reply to Brian, 04-15-2000 16:11:21
If your's is like my HR-6, you have to pull a circlip on the end with the grease fitting, remove the grease cap and take a nut off the end of the shaft. The rotor shaft should pull out then.
I'd cut a new gasket from gasket stock for the chain case cover, and use permatex on it. I'm not sure what gear oil will do to silicone.
