Need an opinion on NH 329 Manure Spreader
Clefus
02-16-2008 19:53:10
I found a NH 329 PTO spreader for $ 400 ....
I t needs wood a little tin work, and a new chain....
I can handle the tin work....wood wont be too much....
Question is the chain....it takes a 67H chain...parts diagram calls for 202 links....
I would have to buy 4 rolls at 52 links/roll.....
TSC way too pricey.....Balsters had it priced at $509.08 per 100 ft....works out to $51 per 10' roll....do they sell just 10' rolls or must you buy the whole 100' ( in 10' rolls) to get that price??
Also the apron bars require 15 LH and 15 RH attaching links.....are these only available thru New Holland ??
Just wondering if it will be worth it to buy this and fix it by putting $3-400 in it or forget it....
I dont spread a lot in a years time but am willing to fix something up to save a few bucks....plus newer ones are pricey....
Thanks
Dave Sherburne NY
02-17-2008 11:27:55
 Re: Need an opinion on NH 329 Manure Spreader in reply to Clefus, 02-16-2008 19:53:10
Like the others said Check that axle. My son has replaced a few with a square tube that will oulast the spreader. As far as a new Apron Chain
we usually get them from Albus Conveyor any size you want.
Clefus
02-17-2008 09:35:45
Thanks guys
Oliver t .. can you e-mail me that info at ddcnphillips@alltel.net ??
PM isnt working at this time....thanks
I will go check out the axle this week.....waiting for this rain to burn some of the snow off....
kossuth
02-17-2008 09:22:15
 Re: Need an opinion on NH 329 Manure Spreader in reply to Erv Adams, 02-16-2008 19:53:10
ktheo1 said: (quoted from post at 08:38:24 02/17/08) Before investing a dime in it get under it and check the axle under the bed .They were stamped sheet metal and liquid would go thru the board floor and collect in it and would rust it out .Pi$$
poor design.It sounds to me like you will invest about $500.00min.plus $400. to make a spreader
worth $900.00 or a 1000.00 when you get thru.
I second this. Check the axle to see if it is in good shape. If it is questionable then don't do it. The chain and sheet metal isn't such a big deal. Structure issues are another matter entirely.
ktheo1
02-17-2008 07:38:24
poor design.It sounds to me like you will invest about $500.00min.plus $400. to make a spreader worth $900.00 or a 1000.00 when you get thru.
Bret4207
02-17-2008 07:29:30
Have one. Replaced the chain with t-bar, much stronger. The floor can be replaced with treated 5/4 SYP. My biggest problem has been the lack of a real axle. NH uses a box frame setup to support the wheels. It sux. I ended up u-bolting a section of lolly column across the axle area. Works good now.
Nice small spreader, lightly built. Doesn't do anywhere near the job my old IH M-200 ground drive does as far as shredding.
Oliver_t
02-17-2008 07:18:12
T-bar chain complete with cross bars from a well know catalog is 398.00. E-mail me for name as I can't post here.
Michael Soldan
02-17-2008 06:47:36
Clefus, I have a 327 spreader. I priced new apron and wood just for the nuts of it. The local machinery dealer can get me the new wood kit for $140..all pieces cut and drilled and ready to bolt in, I believe the new apron chain was $385. I took a few cross pieces to the local welding shop for repair, bought 6 repair links and the spreader is working fine. I may get the wood kit and do the floor then the spreader would be like new. I always pressure wash and oil the spreader when I am done using it..it has been a very reliable spreader.
730virgil
02-16-2008 20:28:48
see if you can find a gratz? chain for it. better chain and you don't need lot of tools to install. i don't remember who sells them.
