I have a 130 W Case Bailer
Farmallb
03-15-2008 12:34:04
And it is a darn good bailer. It has a VAC style air cooled engine on it. The only bad thing about it is that needles are scare as hens teeth and EXPENSIVE. $150 last count 3 yrs ago and there was only 18 left then in stock. It is a fast bailer of single windrows, and the operators manual says if your going to bail with a Case bailer, then to get with it. I once had a field of haygrazer, and I windrowed it into big single windrows. It was slow going. but I was putting out a bail every 10ft or so. I also have a junk 140W that comes with a pto attachment if I every get too old to start the engine, which at 6o, is getting much harder, I can switch over
