jd plow id
rnmo
04-03-2008 16:54:35
i have a 3 bottom jd plow..has place for hyd cyl to lift and has round spoke wheels on rubber on it...where would i find a number at?.. have looked with no success..also have a jd 2 bottom trip plow with steel wheels..same deal..are they worth anything these days?..thanks for all the help
Bob Collins
04-04-2008 08:55:03
 Re: jd plow id in reply to rnmo, 04-03-2008 16:54:35
From your description it sounds like a 55H plow, there will be no model nunber stamped anywhere, kind of have to take casting #s and match them up. The steel wheel plow may be easier , there should be beam numbers stamped after the words"JOHN DEERE" on top of the beams. Let us know.
Bill-NNY
04-04-2008 15:37:08
 Re: jd plow id in reply to Bob Collins, 04-04-2008 08:55:03
Like Bob said, the hydraulic lift plow probably is a 55H or 66H model and they screen printed the model number on the main beam running above the bottoms. The 2 bottom is probably a model 52 or 4B, which were the more popular of the little plows. The 2 bottom will have numbers stamped on each beam above the moldboards. That beam number will help ID the 2 bottom. On the 3 btm, the size of the main beam running above the bottoms will help , along with some casting numbers that you could read off the plow. A picture would be helpful too.
Bill
