JD 335 baler
AP
04-19-2008 16:27:30
What horsepower is needed to efficiently run these balers? I was told they don"t need alot,
as in 40 hsp would do. You be very slow moving with only 40 hsp, wouldn"t you? Any info would be great. Thanks.
garytomaszewski
04-19-2008 18:26:24
 Re: JD 335 baler in reply to AP, 04-19-2008 16:27:30
Balers are really not that HP demanding, most of the power is used to move the machine and the wagon load of bales. Check the Amish territory lots of Wisconsin two cylinder twenty horse engines powering the baler. Pick the right speed to keep an even feed and mostly the tractor doesn't know it has a load.
phillip d
04-19-2008 17:11:45
We used to run an old 410,4x5 JD with a 5610 that had 52 hp without any problems.If you don't have too many big hills,you could certainly get by no problem with 40 hp,more would be better of course,but will get 'er done if you need it to.pd.
