Updated billhook for poly on Deere Square Baler?
TX656
05-02-2008 04:38:41
I just bought a replacement bill hook but before I install it I would like to make sure it is the right one. (Parts person at the dealership had never heard of a billhook so no hope asking them this question.)
Anyways, I read the following in the June 2007 archives...
"Yes, John Deere had bill hooks that have a little notch under the gripper to enable a better grip on the plastic twine. I put a set in a 214 years ago. I'm surprised a 336 wouldn't have them as standard equipment. The new hooks are easy to install and work well. They will work just fine if you want to use sisal too."
Can anyone tell me what the part # is for this 'poly' bill hook and if it would fit a 14T?
Thanks.
Roger in Iowa
05-02-2008 07:10:34
 Re: Updated billhook for poly on Deere Square Baler? in reply to TX656, 05-02-2008 04:38:41
The part will fit a 14T. The groove or depression in the billhook is deeper to allow the tongue to go deeper into it. The opening between the billhook and tongue is less because the plastic twine is smaller in diameter than sisal.
You will probably have to change the twine disk setting (shims) on a 14T.
Roger in Iowa
RickL
05-02-2008 05:59:10
I don't know if this helps or not but I ran ploy and still running poly through Deere balers and never switched any thing. I am still running Bridon poly 170knot in 7200ft single rolls. Now am running new Holland baler. Its not near the baler the green unit was for me. Next trade will be back to green. Try it first without doing anything.
