Need Operators manual for NH68 Baler
J Heitkemper
05-16-2008 20:05:39
or at the least , info as to where to go on line so as to print a Trouble shooting page for timing sequence and another page concerning bannana shaped bales,,. I have a manual for the 268 baler I own ,, Lot of similarities ,, Thanx Jim
Finn Md
05-19-2008 10:18:41
 Re: Need Operators manual for NH68 Baler in reply to J Heitkemper, 05-16-2008 20:05:39
the NH 68 operators manual has a section on mis-shaped bales and how to adjust. You should buy the manual. These balers need a decent sized windrow.I double rake grass hay windrows and go real slow. Thin and irregular size windrows can add to the banana effect too. Good Luck
Joe(TX)
05-17-2008 18:27:26
New Holland sells them. Search for the manual no.
#42006810 Cost is $11.06
gitrib
05-16-2008 20:25:34
I just bought one on e-bay. It cost me $15.00. Make sure it is for a twine or wire tie.
thisoldfarmer
05-16-2008 20:20:30
Banana shaped bales are usually caused by 1 of 2 things: 1. Bale tension adjusters toward the back of the chamber are not adjusted evenly so one side of the bale is tighter. 2. Hay is not feeding evenly into the chamber: it is either not being pushed far enough in or pushed too far in. If not pushing far enough in check the teeth on the "raker" bar that feeds the hay from the throat into the chamber. If the teeth on the end closest to the chamber are missing it won't push the hay far enough in.
