Broadcast spreaders from wagon
D Ward
04-25-2000 16:48:26
I have a broadcast spreader that fit on the tailgate of a wagon and was driven by chain off the wagon axle. I want to rig it up to run off a 12v motor that I can then hook up to either a truck tailgate or tractor 3 point mount and use the vehicle 12 supply. What rpm should the spreader turn at? I think I saw McCormick on the spreader. Anybody know sources for a 12v motor that would work?
LWT
04-26-2000 16:46:41
 Re: Broadcast spreaders from wagon in reply to D Ward, 04-25-2000 16:48:26
Tractor Supply sells a spreader that can be mounted on a tractor drawbar, truck bumper or on the back of an ATV. These spreaders have a !2V motor on them already ready to go, just hook to a battery and go, but maybe you want the fun of making one yourself.
D Ward
04-27-2000 16:46:28
 Re: Re: Broadcast spreaders from wagon in reply to LWT, 04-26-2000 16:46:41
That and hopefillu about $300 less expense. I hope to find a motor for under $50 and I should be able to scrounge the pulley.
paul
04-26-2000 22:59:30
Fertilizer speed should match ground speed (faster you drive, the faster it spreads...) so how do they match that up?
--->Paul
D Ward
04-27-2000 16:50:15
 Re: Re: Re: Broadcast spreaders from wagon in reply to paul, 04-26-2000 22:59:30
DC motor speed can be controlled by a reostat (I think thats right). Maybe set 2-3 speeds to cover most situations.
I know this is getting complicated and TSC is looking better.
