Need help to fix rotary cutter
agnel matt
05-19-2008 12:04:09
Dear lads I bought a rotary cutter 8 years ago. It was yellow and it had no name or nameplate. It is made in the USA it is heavy as hell and is 15 years old. Do to use I need to replace the oil seal in the gearbox and need help to find a seal please help.
James Howell
05-19-2008 20:05:57
 Re: Need help to fix rotary cutter in reply to agnel matt, 05-19-2008 12:04:09
I agree withe maxwell99.
Fill the gearbox with John Deere Corn Head Grease.
third party image
One 14 ounce tube is $3.50+ and looks like lime pudding.
third party image
Filled the gearbox on my JD #5 mower last weekend before cutting hay.
third party image
Worked out OK and stopped the oil leak.
Hope this helps.
Matt Agnel
05-19-2008 16:45:05
third party image
Thanks lads so far Here are some pictures of the seal
maxwell99
05-19-2008 14:36:11
just fill gearbox with grease, I believe you will be ok.
Let others jump in here, but we have run many old gearboxes for years filled with grease.
Best grease if you are high dollar is John Deere corn head grease.
Good luck and stay safe,
KEH
05-19-2008 12:34:54
If I understand you right , the gearbox is leaking oil. If it is the bottom seal you have to take the blade carrier/stump jumper off the bottom shaft. On my old Bush Hog it had left hand threads. If you can fish the seal from the end of the shaft you can take the old seal to a bearing supply place and they can probably match it up. If it is the front shaft bearing getting to it will, of course, be easier. I was advised to just fill the gearbox with grease since grease seal repairs didn't always last too long. There is a difference of opinion here on the grease solution. My bush hog had non grease related problems and I solved them by buying a new one.
KEH
