Finish Mower question
OldKyJim
06-18-2000 20:40:55
I have a Value Built 5' finish mower on the back of my Ferguson To-30. The combination has worked well the last couple of years, but now is giving me problems.
The deck comes to a "point" on the front side that faces the tracot'r PTO.
My mower deck is scrapping the turf, and its this "point" area that seems to be scrapping.
The deck didn't do this last year or earlier this year. I wonder if the geometry of the deck has changed, or what's going on.
The deck appears to roll just fine on all four wheels under operation. Traveling over some hills and slopes, the deck itself seems to bottom out.
My thanks in advance for any suggestions. My next move will be to raise the deck.
Thanks,
Jim Brooks
Mudcat49
06-19-2000 04:50:12
 Re: Finish Mower question in reply to OldKyJim, 06-18-2000 20:40:55
Sump-pin may of got bent, check it out with a level,
'Nother thing, is the top link floating? When you are mowing it should be loose and floating. Iffen it is not and is pulling the front of the mower down and foward that will cause it to dig in at the point.
