Cutting Hay with a Bush Hog?
Jim H.
06-27-2000 14:22:21
I've seen people talk about cutting hay with their rotary-type brush cutters, and my question is this: Is there an advantage to doing it this way? The way it's been raining here in PA, my sickle-bar cutter is "pushing" the thick undergrowth that's been growing in my hayfields. Problem is that the thick stuff is getting caught on the rock guards, and then we're not cutting anymore, we're just pushing the hay down. The problem isn't my cutter, but I'm wondering if a bush hog would work better in this situation. I don't have a cut-conditioner, or even access to one, but I may be able to borrow a bush hog. Also, I was wondering if a bush hog would be more likely to "tear up" the hay, maybe helping it dry faster? The way it's been raining, I almost have to bale between the raindrops! Thanks in advance, Jim H.
george s
06-29-2000 16:23:49
 Re: Cutting Hay with a Bush Hog? in reply to Jim H., 06-27-2000 14:22:21
I followed Dr.Burrhead's instructions and cut surplus pasture into hay this past week, it was stemmy and seedy, but the hay cured into pretty nice soft hay.If I was to cut it on time, it would have been much better than the crap we're forced to buy here. Now, If only I had a proper rake...
Mike (MI)
06-28-2000 17:03:56
I had the same problem with one field. There is some fine grass in there, and the sicle bar won't cut it - it just clogs up. Dad thought I was nuts for using the hog, but it dries much faster. Thank God I'm not the only one to try it! Have to use what ever works, I guess.
hay
06-27-2000 17:11:05
i cut my hay with a bush hog. i removed the left side panel off the "hog" and then lower the front as low as it can go without dragging and raise the rear. that will let the 'hog' cut the hay only once and not keep chopping it up. it will NOT look like a sickle or disc cutter job, but you will still make good hay from it. LOL
Burrhead
06-27-2000 20:10:40
 Re: Re: Cutting Hay with a Bush Hog? in reply to hay, 06-27-2000 17:11:05
It dries alots quicker when you cut it with a bushhog, it crushes the stems so they dry softer and quicker.
I use my hog on all I cut now, it does better than the sickle will do and there is'nt anything to clog up. If it's wet enough to ball up the grass with the hog just run back thru it with a tedder or run back thru with the hog raised up some more and scatter the grass out better.
HUBB
06-28-2000 20:35:48
 Re: Re: Re: Cutting Hay with a Bush Hog? in reply to Burrhead, 06-27-2000 20:10:40
Do you find that you needto rake the hay intoa windrow after using the bushhog, or can itbe baled the way the mower leaves it? Sounds like a promising idea!
Burrhead
06-29-2000 15:02:21
 Re: Re: Re: Re: Cutting Hay with a Bush Hog? in reply to HUBB, 06-28-2000 20:35:48
It still has to be raked. The left side of the mower has to be off the mower like hay said. That makes it scatter the hay out pretty good unless you're in heavy wet grass.
The big advantage to it that I have found is that the hay is a better quality than when it's cut with a haybine or MoCo either one.
Usually with the bushhog cutter you gain a day on the baling because the hay dries so much quicker you can bale a day sooner. This gives you a better protein count and greener hay because the sun does'nt bleach all the nutrient out.
I put up all my hay with a bushhog cutter because it's more tender and nutritious hay than conventional cut hay.
Another concideration is price. The new 6' disc bar cutter around here is about $5490, new sickle bar is $4970, and a new Howse or International 6' bushhog is about $595 to $650. I've been using a Howse for 12 years, and I've only put 2 sets of blades on it in 12 years. The deck has long been rotted off, but it does'nt matter for hay cutting.
