Bush Hogging With Deck Raised
Kevin
07-12-2000 10:34:24
I'm trying to control weeds around some pine saplings that I planted last spring and I can barely see the trees through the weeds any more. I was thinking about raising the bush hog so the tail wheel is not on the ground and straddling the rows of trees to cut the weeds about 2 feet above the ground. Any problems with this? Will there be too much strain on the 3 point to hold the deck up?
Russ
07-14-2000 19:41:28
 Re: Bush Hogging With Deck Raised in reply to Kevin, 07-12-2000 10:34:24
Kevin, You can use Roundup right next to your seedlings. Roundup is a broadleaf herbicide, safe for plants with needles. Many of the Christmas tree growers around here use it. If your not comfortable with my advice, ask the local extension service agent. Burrhead is right, you can`t be too safe. Been reading about alot of Bush Hog accidents lately. The accounts of the accidents paint some pretty ugly mental pictures. Also think about anyone else who might be in the area who could be hit by flying debris. I`ve seen a softball size rock thrown about 70 yds IN THE AIR from mine.
BART
07-13-2000 08:38:07
IF THE SAPPLING IS OVER THREE INCHES TALL YOU CAN GET SOME STUFF CALLED SURFLAN IV HERE AND SPRAY. IT WILL KILL THE GRASS AND WEEDS BUT NOT THE TREES. PRETTY EXPENSIVE THOUGH. YOU CAN BUY IT OR SOMETHING SIMILAR AT NURSERY SUPPLIERS.
Kevin
07-13-2000 09:02:24
 Re: Re: Bush Hogging With Deck Raised in reply to BART, 07-13-2000 08:38:07
Thanks. That sounds just like what I was looking for. I've planted over 1,000 pines in the last 2 years and week control is starting to get overwelming.
Kevin
07-13-2000 06:37:16
I guess that wasn't such a good idea. I won't try it. Thanks for the advice. Someone told me about putting a stovepipe over the sapling and spraying around it with round up. That sounds a lot safer.
BFO
07-12-2000 18:30:21
Burrhead and Steve are right. I had the same problem a few years back on a rental farm. The seedlings were planted 12 ft. by 12 ft. so I was able to cut cross ways. It didn't turn out too bad, I was able to get fairly close, even though the seedlings were almost completely hidden at times.
Burrhead
07-12-2000 15:15:45
For safety's sake please Kevin, don't bushhog with the mower 2' off the ground. A friend here was going to save a few minits like that several years ago and he still must be saving time. He's been buried 4 years from a part of a fence post slinging through his back and eventually killing him. I'm sure he did'nt think there was any danger or objects in his pasture either. He had his bushhog raised up to miss fire ant hills.
They is'nt a tractor or bushhog either one that's made to safely operate like that. Keep that bushhog on the ground. You won't be able to steer the tractor if you hit a chug hole, and that bushhog becomes a missile launcher when it's off the ground.
If the tractor is heavy enough to hold the front wheels down enough to steer right, the debris from under the deck will still come after you. That bushhog spins with enough force to pick up and sling a fence post, or tree limb, or rock, or piece of wire completely through a man, or steel building walls, car windshields and car doors.
Another thing is that the mower won't be stable enough to stay up off your trees anyways. I put out seedlings from time to time myself. You'll be better off to just wait til winter when the grass dies down to see the trees.
Kevin please remember that you can be safe and careful alots of times, but you only get killed once.
Steve IA
07-12-2000 14:42:18
There will be extra strain on the pto shaft knuckles when they are not lined up. The longer you run like this, the shorter the life of the u-joint. Safe mowing
Steve
BART
07-12-2000 12:32:34
I HAVE DONE SOMETHING SIMILAR. JUST MAKE SURE TEH PTO DOES NOT HIT THE DECK. IF IT DOES IT CAN BE VERY DANGEROUS
