Cultivator info needed
Tom
07-19-2000 09:26:02
Hello-
I am trying to find info on a cultivator I would like to use on a small garden. I own a JD 830 diesel utility tractor. I am planing on using it on a 1 to 2 acre garden. Because of the small size I am not too worried about the number of passes I need to make. I would appreciate any info given regarding models and manufacturers. Searching the archives seemed to suggest that the trend in farming is going away from cultivating but it is still a good tool for small plots - any thoughts? I would like to find something used if possible. I was also wondering is it worth the extra money for a rig wide enough to break up behind one or both of the tires or would a small setup that only loosens behind the tractor work OK. The tractor has a 3pt, is there an advantage to the 3pt cultivator or would a drag cultivator also work out?
Thanks
Tom in western NY
Halbert
07-21-2000 13:35:02
 Re: cultivator info needed in reply to Tom, 07-19-2000 09:26:02
No matter what you're talking about, you want it to be at least as wide or slightly wider than the tractor so you dont leave a track.
steve
07-20-2000 16:58:26
Tom, you can a one row cultivator at many farm stores that will work just fine, Thats what i use in my garden. They are 3 point hook-up.
TomH
07-20-2000 16:56:44
Please clarify what you are after. "Cultivating" to me means killing weeds between the rows, a cultivator normally mounts on the tractor or hitch and only makes a single pass. I think you are talking about what I would call "tillage", or preparing the soil for planting with a plow, disk, and/or harrow. If that's what you mean, a pull behind 6-8 foot wide disk and a cultipacker or spike harrow is plenty to get you going. A disk that mounts on a small tractor's hitch is too light. Add a moldboard plow later. Two acres is a lot of garden! Are you going into the truck market business?
paul
07-20-2000 20:07:02
 Re: Re: cultivator info needed in reply to TomH, 07-20-2000 16:56:44
I too am unsure if he means 'row cultivator' or 'field cultivator'. Where I live there are few 'small' field cultivators, they are 12' or more, 10' at least. I guess I see new things at the farm stores, but I tend to feel these things are too light to toy with.
--->Paul
