JD No.38 semi-mount mower
adrian
07-26-2000 21:03:01
How can I attach this mower to my tractor?It is a JD620 3pt,
Jack C. Anderson
07-27-2000 09:56:34
 Re: JD No.38 semi-mount mower in reply to adrian, 07-26-2000 21:03:01
You need to get some mower brackets to bolt to your drawbar frame. I believe the #38 replaced
the #8 which replaced the #5.
check www.shaysnet.com/~rainbow under his antique implements section/mowers you will see the brackets for a quick attach mower.
