Cutter-bar end bearing replacement on disc mower?
john
08-16-2000 17:40:24
does anyone know anything about how to replace the end bearing on a disc mower?
is it a job or is it pretty easy?
any help would be appriciated.
Z-bar
08-16-2000 22:36:40
 Re: Cutter-bar end bearing replacement on disc mower? in reply to john, 08-16-2000 17:40:24
John, it depends on the brand of mower. If its one that each cutter section is seperate, its easy, if its like the vicon, or older john deeres and others you have to take the cutter bar off the mower, lay it on 2 saw horses up-side down, remove the bolts all the way around it, split the bar, then you can replace the bearings. And thats not real easy ether. Most of the mowers use metric bolts (18) mm. luck.
