Bushoggin' hay......
Casey in Ky
08-19-2000 20:24:43
Alright, I think I've finally decided to give it a try(With all the rain we've had this year everything has a real thick undergrowth and cuttin' with the old Ford sickle can cause a man to lose what little religon he's got real quick). I've got a newer, but still fairly cheap, Bush Hog Razorback which has been a surprisingly tough mower(I've cut a lot of 2 inch stuff with it and it's still like new...knock on wood).
But I do have a question or two. I know that you cut the left hand side out, but do you sharpen the blades or not? And what about speed?? How fast are you guys able to cut with these doctored up hogs?
I've been thinking about a new disk mower but that's an awful big chunk of change just to cut hay. Although I will have to admit that those things are the stuff. But if usin' hog works almost as good and helps in the cure time I'm all for it. Any suggestions?? Thanks. Casey
Jon
08-21-2000 15:48:42
 Re: Bushoggin' hay...... in reply to Casey in Ky, 08-19-2000 20:24:43
Ok, I am assuming that what you call a bush hog we call a Slasher in Australia, please someone correct me here if I'm wrong on that.
I've never cut hay with mine, but, I have been told that you are supposed to have the slasher go over the grass at least one and one half times. So I use low third on my FE35 which I think is around 3 kilometres per hour.
Everyone else has answered most of your questions. I believe that you could travel considerably faster with a disc mower (but on my terrain not sure that I would like to go any faster.
Burrhead
08-21-2000 07:08:22
There's some pretty good ideas here but I'll tell you how I use my hog. I've been using mine for several years and have a disc mower and sickle bar cutters, but the hog will out do both of them as far as ease of operartions and quality of hay.
I keep my blades sharp and keep the deck only slightly lower in front. I keep mine in the same position it would be in if I were just bushhogging and not cutting hay. That way it cuts the grass and crimps it as it's being discharged.
The main problem you'll have using a hog is setting you're ground speed to match the blade speed.
If you go too fast it won't cut good.
If you go to slow it will grind the grass too fine.
When you have your speed matched out right, the grass will be cut from 6" to 12" long, and will be crushed from one end to the other like it's been thru a crimper.
You'll probly save at least a day on cure time, and you'll have some of the most tender hay around. Another advantage is the higher protein count in the hay. When it's run thru the hog and cured right you'll usually have about 3% more protein than when cut and cured using a disc or sickle bar mower. I think that's from the quicker cure time causing less leaching.
hay
08-20-2000 03:35:49
disc mower is the BEST way to cut, but a bush hog can do a very fine job, also. i cut the entire left side panel off my bushhog all the way from the front to the tailwheel. lower the front of the mower as low as it will go without scraping the ground and raise the rear as high as it will go. that will allow your bushhog to cut , but not, chop up the grass as much. i run about normal bushhog speed. expierment with your speed, whatever works for you is best.also, yes do SHARPEN them blades razor sharp. take them off and grind them to get a good sharp angle. you will do a much better job.you will have somewhat shorter hay than with the disc cutters, but the cows won't mind. the hay will also cure faster since it is not as tall. LOL
Rob Campos
08-20-2000 14:48:19
 Re: Re: Bushoggin' hay...... in reply to hay, 08-20-2000 03:35:49
I live in central Iowa, does anyone have any advice of where to look for a good used bush hog that I can pull from my drawbar. ALso, what is the difference between a bush hog and a rotary cutter??
Thanks
Rob
Rick Lees
08-20-2000 08:31:26
I have a Bushhog 306 pull type that has bolts in the left side so you can just take it off. This thing is built out of 1/4 or better steel The front hitch is on a frame so it can be lowered and I put a cylender on it so I can raise it up with out getting off the tractor. It sure cuts nice and leaves it in windrows. I bought new blades for the thing 14.00 apiece and the bushings they ride on for 5 bucks apiece. The worse thing about this thing is if you run over anything whil bushhoging it throws the stuff out the front so a guard on you tractor to keep from getting hit in the head is a must. They also say that if theres a blacksmith around heating and pounding those blades out makes them last longer in stead of grinding on them. I'm not much of a grinder or blacksmith so I found them and bought them. Good Luck
Charlie
08-20-2000 10:27:38
 Re: Re: Re: Bushoggin' hay...... in reply to Rick Lees, 08-20-2000 08:31:26
Will a bushog work on alfalfa OK?
Burrhead
08-21-2000 06:51:40
 Re: Re: Re: Re: Bushoggin' hay...... in reply to Charlie, 08-20-2000 10:27:38
The hog beats too much for alfalfa. It knocks off the leaves and all you have left is the stem.
hay
08-20-2000 12:10:17
no expierence with alfalfa.
Rick Lees
08-20-2000 16:57:22
 Re: Re: Re: Re: Re: Bushoggin' hay...... in reply to hay, 08-20-2000 12:10:17
I don't have any experience with alfalfa just fesque and thimothyand that experience could be questioned LOL
