Brush hog help
bill a.
08-30-2000 13:25:48
I just boght a King Kutter 5ft. brush hog. first my MF50 only lifts it enough for the brush hogs back wheel comes off the ground, is this right and if so how do you get underneath the hog to change or sharpen the blades being it's so heavy.
CHRIS-MF35
08-31-2000 18:30:22
 Re: brush hog help in reply to bill a., 08-30-2000 13:25:48
with the postion handle all the way up pull the draft control handle up, if it raises more the draft control needs work. that what my 35(same lift sys) did before it jammed and wouldn'tr go back down with the tractor running. hope it's just a toplink unscrewed to far. good luck
Halbert
08-30-2000 17:39:10
How's it lift other heavy implements? You may need work on your pump etc. I believe when you are mowing, the top-link should be adjusted so that the back of the hog deck is 1"-2" higher off the ground than the front. The wheel should lightly or occasionally touch the ground. Maybe someone else can tell us better. Be careful.
Chuck
08-30-2000 16:15:01
I agree with burrhead. I use a 6' King Kutter on a MF 135. Shorten toplink, disconnect pto and definitly block the hog up. I use red oak blocks. Be careful.
CB
Burrhead
08-30-2000 15:59:46
Please, please don't rely on the lift to service your blades.
Take the pto shaft off so it does'nt hit when you raise the hog, shorten the center link til it's as short as possible, then raise the mower and block it up with something solid like cross ties or heavy concrete blocks.
One of our local school ag shop teachers was killed 2-3 years ago by relying on the hydraulics to work under his bushhog. The hog came down across his chest&stomach and he was suffocated from the weight. He was one of the most safety minded folks I have ever seen.
Remember you can be safe as many times as need be, but you only get to be killed once.
big fred
08-30-2000 18:54:39
 Re: Re: brush hog help in reply to Burrhead, 08-30-2000 15:59:46
I gotta agree with Burrhead, never get yourself into a position where a burst hydraulic hose can kill or maim you. Always SECURELY block anything supported by hydraulics before you get under it.
BFO
08-31-2000 07:46:17
 Re: Re: Re: brush hog help in reply to big fred, 08-30-2000 18:54:39
Right about the safety issues. I usually jack up the cutter and place axle stands on the four corners while attatched to the tractor. That way, as long as the tractor is in park, the cutter can't slide off the stands
