Hey B.C.! Tell me more about the parking cradle.
Jim.UT
08-30-2000 18:54:54
You mention building a parking cradle for your JD #9 mower. I've been thinking along the same lines for mine. Can you email or post a picture of what you built? If not, can you elaborate on how you built it, how it works, what you would do differently if you were to do it again? Thanks.
B.C.
08-31-2000 10:44:41
 Re: Hey B.C.! Tell me more about the parking cradle. in reply to Jim.UT, 08-30-2000 18:54:54
Version 1.0 was based on a discarded engine shipping skid that the place I was then working for had thrown out. The neighbor and I built a couple uprights out of it. The rear end of the mower would rest on the end of the skid, the arms of the mower that bolted to tractor lift arms, rested on these uprights.
Then we also built what looked like a bench, to support the sickle bar about a foot and half off the ground. This thing was some 7 feet long.
One would back the mower over the skid, with the sickle bar chained vertical in the normal travel position. The mower would be lowered onto the skid. Then the sickle bar would be lowered onto the bench. In this manner it was then easy to unbolt the mower from the tractor, and when the tractor was driven away the mower would sit there.
Hooking up was basically the reverse of what's described above.
Version 2.0 was simpler and came about after 1.0 rotted away. A plank provided support for the rear of the mower to rest on. The bench stayed the same. Two supports, each about 1 1/2 feet high were placed under the lift arm deals to hold them up.
The first time I ever put that 9W on the MH 50 it took me about two hours working alone. When we had the cradle figured out it was down to 5 or 10 minutes, with a lot less swearing.
Jim.UT
08-31-2000 12:21:17
 Re: Re: Hey B.C.! Tell me more about the parking cradle. in reply to B.C., 08-31-2000 10:44:41
I hear you on the first time hookup blues. Took me about the same. Then I promptly parked the end of the blade into the wire fence on the first pass. Had to detach everything, hook a chain to it and drag it sidways out of the fence then reattach everything in the field. I can do it quicker now, but that cradle would still be a better setup. I'm still a little fuzzy on the bench for the blade. Do you store the mower with the blade in the upright travel position or is the bench long enough that you lower the blade while it sits on the cradle? Is there an advantage to storing the mower with the blade up or down? I've always just left it in the upright position. Thanks.
B.C
08-31-2000 13:52:36
 Re: Re: Re: Hey B.C.! Tell me more about the parking cradle. in reply to Jim.UT, 08-31-2000 12:21:17
We lay the bar down on the bench last thing before unhooking the mower from the tractor. Then the weight and moment(if you will) of the bar isn't wanting to twist the mower. The sickle bar is then supported (to a great extent anyway) by the bench.
I'm not saying this is the only way to do it. It's just what's worked for us.
