Howse Implement Co.
Chris
09-04-2000 04:16:35
Anyone have any ideas where I can obtain replacement parts for a disc manufactured by Howse Implement Co. MS? I've searched and can't find a source anywhere.
Josh Riley
06-17-2002 11:37:21
 Re: Howse Implement Co. in reply to Chris, 09-04-2000 04:16:35
For a bush hog ( i needa price)
mfg.:by howse/implement co.
Model: #500
Serial# 0613966197 Gear box, planetary gears bearing and casing
thanks
Burrhead
09-04-2000 07:22:27
Just about any bearing you need is available at Tractor Supply or Motion Industry, Dixie Bearing, or NAPA. Just take what's left of the old one and the race so they can get the ID and OD of the bearings.
The disk blades and axle shafts are a universal fit and Tractor Supply has them. The gear boxes are off brand Tiawan selection. They put whoevers gear box on that's cheapest at the time they run low.
Universal Gear or Gears Plus are cheaper on the cogs than Howse and are better quality than original. If the gear box has chewed up the cogs you might be better off to find a box at the scrap yard. The Howse box was'nt worth a flip when it was new.
Howse Implement Co
PO Box 86, Highway 84 East
Laurel, Ms 39441
ph 601-428-0841
fax 601-649-6759
Hope this helps and good luck.
Dave M
09-04-2000 07:21:55
Have you tried asking these guys?
rod
09-04-2000 06:57:28
Howse has a website I was there a few days ago. Try www.mower-parts.com
regards
rod
