IHC wire tye stationary baler
rod.
09-07-2000 13:34:57
We have the above baler which we would like to out more about,in fact anything,age,model etc,can anyone make any suggestions where to look for a model or any other tell-tale signs?-thanks
B West
09-23-2000 17:40:31
 Re: IHC wire tye stationary baler in reply to rod., 09-07-2000 13:34:57
My uncle has a John Deere Dain hay press, the only way he found out what year it was, was to look at sales lititure from the early 1900's and find one that looked like his, witch put his at about 1919. By the way if you don't want to use wire to tie the bales you can use a home made needle to push through the block and hook a piece of twine with a loop on the end and pull it through, then hand it to the man on the other side and he can shove it through to you and then hook it again then pull it through the next block (just like the wire)then tie it. Good luck!
