Disc bearings
Tom Krizman
09-24-2000 17:45:21
Bought my first set of discs at an auction. 61/2 foot, 3 point hitch made by Ford. Plate states that they are a Series J with a serial number of I2984. Can not read Model Number. Are there supposed to be bearings inside of what appears to be bearing caps on the outboard end of seach set of discs? Each cap has two grease fitting. I took one of the caps apart and it was full of dirt. No grease and no sign of any bearings. Help
LazyHorse
09-24-2000 19:39:02
 Re: Disc bearings in reply to Tom Krizman, 09-24-2000 17:45:21
On the few I worked with none have had actual bearings, sometimes just remnants of rubber bushings, just clean the mud out and grease well, should work fine as they need a little play to work well.
paul
09-24-2000 19:24:34
I'm no help on figuring out models, but many older disks had wood block bearings.
--->Paul
