Grading with a 3 point snow blade
dan from mi
09-25-2000 17:34:12
i have a 6 ft blade on the rear of my 971. i need to use it to grade loose sandy soil. as you might expect when it meets much resistance it raises up and that makes it difficult to maintain grade. would weight improve its performance? if so how much weight? is there a way to rig a rigid bar to lock the blade at a given elevation?
thanx dan
george
09-26-2000 06:24:10
 Re: grading with a 3 point snow blade in reply to dan from mi, 09-25-2000 17:34:12
Dan:
I've added weight to mine also. I use two pieces of steel angle held in place with c-clamps. It adds about 200#. I also extend the top link to maximum...this gives the blade more "bite". Angle the blade and make a single pass. Then, with the blade still angled, make a half-pass. Your initial pass will guage the next pass, and so on. After you grade in one direction, turn and grade perpendicular. It's a slow process, which is best performed with a dozer, although it can be done. Also, I try to break up the soil first with a cultivator. This really helps.
Good luck!
paul
09-25-2000 19:40:29
Weight can help.
You don't actually want it locked ridgid, that wouldn't work out. Leveling ground with a blade is a long slow process to do it right.
I have a 960 with a 8' blade, just worked on the driveway today, as well as in the cow yard.
Angle the blade, more is better. Move the dirt over to one side, then back to the other with the angle. Just run laps up & down the driveway with the blade angled.
If you are trying to move dirt from point A to point B, well, a back blade isn't the best tool, but you can do it - it will just be slow work.
If you are trying to level a bigger area, use the angled approach on a bigger scale. :)
To finish off, I turn the blade around & use it backwards (aimed backwards, but drive forwards) make a few passes that way to really smooth things off.
The tractor moves up & down as the front & rear wheels go over bumps. Making the blade ridgid creates more & more bumps - never get things leveled off. The secret is angling the blade, that gets rid of the bumps.
--->Paul
John
09-26-2000 10:40:45
 Re: Re: grading with a 3 point snow blade in reply to paul, 09-25-2000 19:40:29
Paul, I am facing a similar problem -- got done plowing and discing a paddock to reseed/relevel, only it looks like the ocean out there -- waves. I'm trying to work it with a 3-point blade on the back of the tractor. Are you saying *not* to keep it rigid? That makes sense. So should I remove the top link and just drag it with the liftarms? Or just take the tension out of the lift arms so it can ride on the ground instead of digging or lifting as the front of the tractor goes into bumps or over mounds? OR, should I reverse the blade and just go at it backwards like a bulldozer?
paul
09-26-2000 20:40:53
 Re: Re: Re: grading with a 3 point snow blade in reply to John, 09-26-2000 10:40:45
I assume your tractor 3-point floats up, just acts like dead weight. That's good, let the blade move upward if it wants to.
The only way I can get rid of the waves is to angle the blade so it pushes dirt to one side a bit. More angle seems better. Then hit the ground in different directions. It will level out eventually.
An angled blade will hit the waves at different spots, & pull them apart. If you leave the blade straight, it just goes up & down over the waves, not really changing them.
--->Paul
ChrisN
09-27-2000 08:27:45
 Re: Re: Re: Re: grading with a 3 point snow blade in reply to paul, 09-26-2000 20:40:53
Blade works best with loose materials. Instead of using a pulled blade to grade "fresh" ground try this. The solution that works for me is create a "box scraper" device. Attach 3pt field cultivator and mount a 2x12 pressure treated board between the tines. I was in hurry so I just tied the board loosely in front of the back row of tines. The teeth of the cultivator dig in slightly as I pull the cultivator. The board keeps the cultivator from going too deep and can raise the 3pt as well if needed. The board pushes the loose soil and levels out. Quick and dirty solution to grading. Finish with just the blade to smooth surface.
John
09-27-2000 09:52:46
 Re: Re: Re: Re: Re: grading with a 3 point snow blade in reply to ChrisN, 09-27-2000 08:27:45
Thanks for the guidance, gents. We got 4 inches of rain yesterday so it might be a day or two before I can get back into that field to do it.
Thanks again -- John
