Haybine rolls
dan
09-29-2000 12:11:56
Is there any other place to find rollers than a New Holland dealer. Is there any place to have them recoated? Thanks
David
09-29-2000 18:59:21
 Re: Haybine rolls in reply to dan, 09-29-2000 12:11:56
There are used haybines everywhere. Most dealers have at least a few, and many dealers are loaded with them. You can check around for your model, and you will probably be able to find an entire machine cheaper than buying new rollers or having yours coated.
Tim(nj)
09-29-2000 19:42:04
 Re: Re: Haybine rolls in reply to David, 09-29-2000 18:59:21
Not here. Saw a NH 477 sell off a dealer's lot for $3000 last week. Haybines are very expensive in this area. For us, it's cheaper to put in new rolls on an otherwise good machine than it is to replace the machine entirely.
jamie bentley
06-26-2002 18:54:07
 Re: Re: Re: Haybine rolls in reply to Tim(nj), 09-29-2000 19:42:04
i'm looking for a drive shaft for a 477 haybine. need the part of the drive shaft from the tractor to the second bearing behind the swing arm can u help?
