Any experiance with 3pt. dirt scoop?
Dave Helms
10-21-2000 20:33:49
I am considering getting a dirt scoop for the rear of a Ferguson TO-30. I would use it for light leveling work and moving around dirt piles. The rear tires of the tractor are fluid filled, so I assume there is enough weight in the back to provide traction. Has anyone had any experiance with these scoops, and did they work up to their expections??
Dave
PAUL
11-16-2000 05:36:03
 Re: Any experiance with 3pt. dirt scoop? in reply to Dave Helms, 10-21-2000 20:33:49
You can buy them at www.farmandcountry.com
Mike (Minn.) '48 8N
10-23-2000 05:52:26
third party image
My 30" Kingcutter Dirtpan (above) has provided many hours of dirt haulin' fun. Even though it only holds 9 cubic feet of soil in the scoop (about 2 wheelbarrows at a time) the thousand pounds or so for each pass saves a lot on the operator, 'specially when haulin' any distance. Of the seven implements I have for 'Henry' the scoop is by far the most enjoyable to use. HTH
Mike (ID)
10-26-2000 12:03:18
 Re: Re: Any experiance with 3pt. dirt scoop? in reply to Mike (Minn.) '48 8N, 10-23-2000 05:52:26
Where would one look to get more info on the Kingcutter Dirtpan? I have a soil scoop and love it--other than shoveling out material. Never thought of turning it around.
Thanks.
Mike
Dave
10-23-2000 18:35:44
Many thanks to all for the replys. I will be getting one. Mike, the pic speaks volumns. Boy do we miss the green of Minnesota! Moved to Colorado 4 years ago from Burnsville. Love the mountains, miss the green!!
Jeff
10-22-2000 20:08:16
I use a 30 inch one on a 25 hp tractor for ditching, hauling dirt ect. works fine for me and a lot cheaper than a front end loader( I still want one LOL)A hyd top link would make it a lot more useful and it does work as well forward as reverse
RWK in WI
10-22-2000 17:23:26
I am using one on the back of a Ford 860. It works good for moving dirt & gravel. i have a Hydraulic top link that makes angle adjustment a breeze and improves the dig angle. Faceing forward it does a great job of diging drainage ditches. Faster than an front end loader and more easily controled for ditching.
Dick Kraus
Sam Mills
10-24-2000 07:55:56
 Re: Re: Any experiance with 3pt. dirt scoop? in reply to RWK in WI, 10-22-2000 17:23:26
Dick, What is the length, stroke and bore of the cylinder you use as hydraulic top link. Been thinking of doing this same thing with my Ford bucket. Thanks
Ray Peterson
10-22-2000 14:58:53
Borrowed one to use on my Farmall 200 - 2 point converted to 3 point hitch. I was hauling gravel out of a pit, worked fairly well, until I got the scoop too far below the level of the tractor, then the 3 point hitch arrangement tended to buckle, and the bucket would tip forward. Also had a little trouble loading when backing into a bank of dirt. As long as you're working pretty much on the level, they work OK. Beats shoveling, but not as good as a front end loader. I am considering buying one in the future.
GaryV
10-22-2000 12:04:08
I just bought one to move dirt & rocks on our land. So far it has worked fine for me. Better than doing it by hand.
Vern
10-21-2000 22:19:30
I have a scoop for the rear (3pt) of my Farmall Super A. It works pretty well in either direction.
Kermit
10-22-2000 08:27:37
 Re: Re: Any experiance with 3pt. dirt scoop? in reply to Vern, 10-21-2000 22:19:30
I have a Ford brand rear scoop. It works pretty good. Since I don't have a front loader I use it sometimes to move some dirt or gravel. Not as good as a loader, but it gets me by.
Dave
10-22-2000 05:01:56
I had never even considered turning it forwards. That would take the kinks out of the neck. My "honey do" list is long and impressive, but not enough so that I want to install a front end loader and deal with the hassels of that.
Thanks for the feed back,
Dave
