2 Bottom Plow Heights
Suggestions.
BlueLight
11-13-2000 06:12:01
My 3PH can only rotate thru a 60% quadrant
so it limits me on how high I can lift the arms.
When I made the system, I patterned it after a
9N with 32in arms and max lift of 30 inches. I can purchase a ferguson plow that is 24inches high from share to attach point but I would prefer a shorter plow. Can anyone suggest a shorter (height) plow.
There is no problem with adapting my system with
a new plow at this stage.
paul
11-13-2000 18:32:40
 Re: 2 Bottom Plow Heights - Suggestions. in reply to BlueLight, 11-13-2000 06:12:01
Just consider that the lower a plow is, the more it will plug up. And that is FRUSTRATING. You want more clearence under the beams, not less. :)
Sorry I'm not helping your problem, but at least don't pay extra for a super low plow - it should be cheaper, because it doesn't work as well.
--->Paul
