3 point 3 bottom plow
Jim
11-14-2000 10:19:12
I'm trying to locate information regarding
this plow. I have a friend that uses his Ford
900 utility tractor with one of these.. He says
its an AC plow, but I can't seem to either locate
it or find any discussion. This to be used
for plowing small plots with my IH 350 RC..I
don't have much turn around space.
paul
11-14-2000 13:34:57
 Re: 3 point 3 bottom plow in reply to Jim, 11-14-2000 10:19:12
I don't know much about it, but AC often used their own special way of mounting older equipment, not the standard 3-point. And IHC tractors of that era often only had their own special 2-point (fast hitch) design, again not the standard 3-point. Is your tractor adapted to standard 3-point?
So, check over what you are getting and make sure they fit on one another.
Many companies made 3 bottom 3-point plows, if you don't care what color it is. :) Harder to find, but IHC made plows with the fast-hitch prongs.
--->Paul
