Footings
Paul
11-17-2000 02:58:09
I need to dig a trench for footings for my new garage I am building this spring. Is there an implement that will let me dig down 20" and about 12" wide. I have a front end loader on my 8N but will not be much use. Thanks for you input. Paul
g
11-21-2000 09:22:39
 Re: Footings in reply to Paul, 11-17-2000 02:58:09
Hire a backhoe and operator. The trench needs to be a specified depth (for frost) and a controlled width. Too wide and you will need more concrete. Also, the bottom must be undisturbed soil for adequate bearing (typically 3,000 psf). DOo it right...this is your home.
PAUL
11-21-2000 03:17:51
THANKS FOR ALL YOUR INPUT. WAS HOPING TO KNOW IF THEY MADE A BACK BLADE THAT WOULD TURN VERTICALLY? IT SEEMS THAT BUD LIGHT IS ALSO THE BEER OF TRACTOR NUTS. WELL I HAVE THE BEER KNOW SINCE I THOUGHT THAT WAS MOST IMPORTANT AND WILL WAIT FOR YA'LL TO SHOW UP.
Ray
11-17-2000 17:57:03
Did you want that trench straight and level? Better make that root beer!
Salmoneye
11-17-2000 06:57:56
Check the archives on the N Board and the Research section to the left and look for 'Trenching With A Plow'.
One bottom works well and a 2 Bottom will go deeper if you remove the front share.
Even if you have to go the last bit down with a shovel, it will save you a whack of time and labor...
Al
11-17-2000 05:10:42
one way is get a # 2 shovel, a case of beer or 2,get several friends[?] over one saturday. It can be done,I remenber years ago me and dad dug a trench 6 foot deep, 3 foot wide and 150 feet long for a water line. didn't have money to hire a backhoe.
Tommy D.
11-17-2000 05:54:26
 Re: Re: Footings in reply to Al, 11-17-2000 05:10:42
Get 3 cases - Bud Light - and I'll be there! May need a ride home though!
TD
Al
11-17-2000 05:10:13
