Cessna hydraulics
Farmer Tom
11-24-2000 21:58:15
Does anyone know where I can get some information on Cessna spool valves, like how to convert from open center to closed center? Help is appreciated!
Jack C. Anderson
11-27-2000 09:51:11
 Re: Cessna hydraulics in reply to Farmer Tom, 11-24-2000 21:58:15
Cessna hydraulics is now part of Eaton Hydraulics. Typically the whole valve needs to change to convert from open center to closed center. You also need a pump with a compensator on it (pressure or load) to use with closed center valve.
If you need more help, let me know
Wardner
11-26-2000 08:46:29
Try the link below. It is a msg board for the Fluid Power Society.
