3 point back hoe
mgb
12-21-2000 16:00:34
Do the 3 point hitch mounted backhoes require duel hydraulic hook ups on your tractor or will a single work?
george
12-22-2000 11:53:32
 Re: 3 point back hoe in reply to mgb, 12-21-2000 16:00:34
Typically, they will require only supply and return lines. There should be control valves on the backhoe unit. For better flow rates, however, a PTO pump and separate resivoir is better.
Lazyhorse
12-21-2000 19:37:05
The woods models use their own pump driven bythe tractors pto.
jlsims
07-29-2001 21:41:49
 Re: Re: 3 point back hoe in reply to Lazyhorse, 12-21-2000 19:37:05
inter rested in building back hoe attachment for my tractor from scratch
RayP
12-22-2000 19:04:30
Father-in-law's PTO powered unit runs too fast, even when tractor is idling. You might want to ask for a demonstration before you buy. Sorry, I can't give you a brand name.
bob
12-23-2000 03:44:29
 Re: Re: Re: 3 point back hoe in reply to RayP, 12-22-2000 19:04:30
my mephew has a DUAL and runs off tractor hdy. it is real handy and will dig six feet deep its mounted on 1086 INT easy to take off etc good machine
