General Use plow behind Oliver 550
Shep
12-25-2000 18:54:40
Seeking some input on a general purpose plow I can use behind my Oliver. I am looking hard at an Oliver 100 Plowmaster, but would prefer a full 3-pth plow. Will be turning ground on a 35 acre pine stump field in N. FL. Comments are welcome.
Dan Kaiser
12-29-2000 07:40:47
 Re: General Use plow behind Oliver 550 in reply to Shep, 12-25-2000 18:54:40
The 100 plowmaster would probably not be the best choice. My guess is you'll spend a lot of time hitching the plow when it trips. Plus the 100 doesn't offer much clearence.
Shep
12-29-2000 08:20:28
 Re: Re: General Use plow behind Oliver 550 in reply to Dan Kaiser, 12-29-2000 07:40:47
Dan -
Thanks for the insight. I am going to pursue a 2 or 3 disk plow. The other plow was nice looking but not suited to my needs. I learn so much from this site.
Shep
Guido
12-25-2000 19:22:10
I would look for an old disc plow. It will do a better job of cutting the roots than a bottom plow.
Shep
12-25-2000 19:46:21
 Re: Re: General Use plow behind Oliver 550 in reply to Guido, 12-25-2000 19:22:10
Guido - Thanks for the info. I have looking for a used one for awhile now. It seems as if once someone owns one they never get rid of them. I have found a local firm that will make one but cost is high ($1800).
See the link>Link
Shep
Bryan
12-30-2000 09:08:31
 Re: Re: Re: General Use plow behind Oliver 550 in reply to Shep, 12-25-2000 19:46:21
I have a 3 bottom disk plow it is IH with steel wheels and works well. I will sell mine, I am located in south central Illinois. My number is 618-686-4691 good luck
Tim(nj)
12-25-2000 20:37:55
Monroe-Tufline also makes disk plows
