Front Wheel Weights for a 8N
Frank P
02-08-1999 13:04:18
I am looking for front wheel weights for a ford 8N .The tractor has a backhoe attachment and the front is a little on the light side.I am also considering ,to fill the front tires.If anyone knows how to build a set please let me know.
Redneck Joe.
02-23-1999 09:37:58
 Re: Front Wheel Weights for a 8N in reply to Frank P, 02-08-1999 13:04:18
At a local lumber yard they used a 55 gallon can cut in half and filled with concrete on the back of a tractor...I don't see why you couldn't do this wht a tractor on the front...this would be basically cheap and frugal...other wise just hook up some tractor weights with a long bolt and they would work the same way...either from the front gaurd or front axle..
