2-bottom plow
Steve
01-17-2001 10:00:39
Just learning: Have a Dearborn (I think) 2-bottom plow. Only has one (1) of those cutting discs mounted. What the heck is the real function of these, should I have two, should they spin, how close should they be to the actual plow, and what is that trailing wheel used for? Would like a lesson in the CORRECT function of the plow components before I attempt to restore it.
jim oren
01-31-2001 15:44:24
 Re: 2-bottom plow in reply to Steve, 01-17-2001 10:00:39
I currently am rebuilding a dearborn plow myself. it is a 14", the model # 10-1 sre # 60f11 i think. the f is hard to make out. Iam currently tring to find the shares and moldboards for this piece of equipment any help in this matter would be helpful.
paul
01-17-2001 15:49:26
The rear wheel also keeps the plow straight, or not pulling over to the left. That is why it is angled. But you are right, mostly for depth control.
There should be a coulter for each bottom, and I run mine as far away from the bottom as possible. Generally they are wore down, and should be a lot bigger than a used plow has. Sometimes in cornstalks it's better without them, but if full size & set up right, they cut up the crop & let it turn under without plugging the plow.
--->Paul
Dave C
01-17-2001 12:15:58
Alan is right about the coulters. They make for a cleaner plowing job in most cases. Sometimes they cause problems in high grass & weeds by plugging up the plow, so they were removed on occasion. However, they are generally a good thing. The trailing or "tail" wheel provides depth control and helps keep the plow level from front to back while plowing.
Alan Farley
01-17-2001 10:49:53
That cutting disc is called a coulter, which scours the sod so the moldboard can turn it over easier(like a pizza cutter in a sense). They should spin and on my plow they are about 1/2"-1" from the moldboard,sometimes closer sometimes farther away.They pivot a little bit to the left. If you have two, use them, it won't hurt anything.
Steve
01-17-2001 12:06:59
 Re: Re: 2-bottom plow in reply to Alan Farley, 01-17-2001 10:49:53
Thanks Alan.
