1 Row Cole Planter
Tommy D
01-18-2001 07:42:03
My father-in-law just gave me a Cole brand 1 row planter yesterday. Since I am totally clueless about planters, I have a few questions.
He bought it new in 1978, and never used it. It has 2 bins, 1 for seed, and 1 for fertilizer (I think). He says it mounts on a modified cultivator (3 pt.), which I have.
Does anyone have anything like this? If so, would it be possible to post a pic so I can see how it mounts on the cultivator?
Any and all guidance is welcomed.
Thanks,
Tommy D.
Hugh
08-22-2004 09:31:03
 Re: 1 Row Cole Planter in reply to Tommy D, 01-18-2001 07:42:03
Cole planter was purchased by Covington Planter and both are still manufactured in Albany, GA please go to www.coleplanter.com and you can see pictures, down load manuals, look up dealers and etc.
Green meadow farms
12-19-2004 07:43:18
 Re: 1 Row Cole Planter in reply to Hugh, 08-22-2004 09:31:03
Hugh.
I have a one row cole planter I am looking for another one used would you be intrested in selling it?
Bill
planzman
01-22-2001 08:13:16
Are the bins side by side? If they are then it is a duplex planter. Each side seed plates turn in opposite directions. This is what I have, you will need right and left plates for what ever you need to plant. Good news is that you can use either side by itself or together when planting a large area or with different seeds in each side for mulitple planting. Works greats, last long time. Powell tells me that I have to buy from them through a dealer. They will not sell direct, I got a bush (30 +) seed plates from my neighbor to use this year. Seed plates have differnt size teeth, and the number of teeth per plate determines the distance between seeds when planting. I have a watermellon seed plate with 2 teeth, and some beans with 16 teeth. Corn might have 6 or 8, 4 would be used with 4 in the other side. Two hoppers just means you stop to refill less offten.
good luck
Dennis Pace
02-05-2003 08:47:25
 Re: Re: 1 Row Cole Planter in reply to planzman, 01-22-2001 08:13:16
I need a fertilizer distribution plate for a 1 row gear-drive planter w/30 teeth. Please reply. Also, do you have a manual or catalogue? Thanks!!!
Dennis Pace
02-05-2003 08:45:49
Halbert
01-18-2001 15:22:58
Cole also sells a 3-pt hitch that bolts to the planter with 4 bolts, if you don't want to use the cultivator. And they have mounting kits to bolt to toolbars if you want to use more than one unit. There is also an accessory to put a rubber tire in front of the planter so that you don't have to hold it up with the 3-pt hitch in soft soil. The rubber wheel also will mash small lumps if your soil is not in perfect shape. Whatever you do, if you use the fertilizer be sure to keep all the shafts greased/oiled up and clean it thouroughly when done, or things will seize up pretty fast. They have added more grease fittings in recent years that were not there in 1978. In 1978 the heavy rear wheels are held in place by a pushed in pin. Replace this pin with a category 0 lynch pin so you can take it off quick and grease the axle and wash any fertilizer off the gears, they added this later also.
Tommy D. - Thanks!
01-19-2001 05:51:29
 Re: Re: 1 Row Cole Planter in reply to Halbert, 01-18-2001 15:22:58
Thanks for all the help! I called and they are shipping me a manual today. Can't wait to get plowin' & plantin'
Tommy D.
Dennis Cotton
01-18-2001 12:53:51
Here is their website.
http://powellmfg.com/products.htm
Robert in Md.
01-18-2001 09:09:11
I have about 5 one row Cole planters but they are all much older than yours.. Your planter is a 12 MX Multiflex Planter. Write or call the Powell Manufacturing co., PO Box 707, Bennettsville SC. 29512-0707 or 1-800-845-9087 and ask for the bulletin for the above. It shows several pictures of the planter fastened to different cultivator frames. Robert
