Found antique implements in shed, need to know value??
Judy Kirchner
01-20-2001 15:26:19
We have discovered an AC 4 row snap coupler corn planter, MM corn sheller, JD Baler model 14 T and AC WD 45 with snowblade in great shape in the neighborhood. Could anyone give us a value on these items?? We may sell them. Thanks!
paul
01-22-2001 08:19:54
 Re: found antique implements in shed, need to know value?? in reply to Judy Kirchner, 01-20-2001 15:26:19
It depends very much on your location, you didn't tell us. If you want top dollar, sell in the right season. What model of MM sheller? Belt drive on the grain leg, or old chain? Does it have all the drag sections? Etc.
:) Hard to do appraisals without location or pics.....
--->Paul
Judy
01-25-2001 08:55:44
 Re: Re: found antique implements in shed, need to know value?? in reply to paul, 01-22-2001 08:19:54
THe MM corn sheller is a model D, PTO drive, single axle with pole. All metal in great shape. NO drag lines. Last used 10-12 years ago and worked great. Been in shed for 20 years at least
Lazyhorse
01-20-2001 16:37:36
I'll give you an idea what those items might bring in Indiana at some auctions I have been to.
WD45 $2000
JD 14T $500
MM Sheller $50 to $75
AC Planter $1 to $150
All this depends on condition, and if anyone is interested. Lot of times they only bring scrap price if no one wants them. I bought a JD planter for $1 at an auction. And a baler for $200.
RWK in WI
01-21-2001 07:00:03
 Re: Re: found antique implements in shed, need to know value?? in reply to Lazyhorse, 01-20-2001 16:37:36
The WD45 could go for quite a bit more depending on the snow plow here in WIS. A WD45 with hyd lift and angle went for 3800 last fall and a hyd lift only but with double weights and chains went for 4100.
Depends on the location, condition, and weather forcasts.
