Anybody know?
F14
01-29-2001 10:53:20
third party image
What the model number of this IH rake is? Two 16" tires on the back, chain drive via in-and-out gearbox to drive the reel. Serial tag is on it, but there's nothing stamped on the model line.
tim
02-03-2001 20:12:07
 Re: Anybody know? in reply to F14, 01-29-2001 10:53:20
I bought a rake exactly like this three years ago and still have it. I had the same thoughts on the model as mine is also quite rusty but not quite as bad as yours, I still have just enough paint to be sure it is IH but could never find a decal or plate with the model number. About two weeks ago I mentioned to a guy that I need to replace teeth for this but not sure of the model #. He had a IH new equipment book from early 1960's. The model 15 looked exactly like mine 5 bar, I think the three point model was a #13. Mine works good, drained the water out of the gear box and put a new seal, bearing, and race in last winter, now only need about 100 new teeth, I bought 50 from a country general store for 10 cents on the dollar going out of business last month and they are all the same but the loop where they bolt to the bar is completely opposite of ones on my rake, not sure what to do with them now.
galen
01-30-2001 14:46:30
Looks like an early Model 15. The rubber teeth are the universal replacement kind I'm betting. Came out with a coil spring tooth when new if it is a 15.
F14
01-30-2001 18:02:03
 Re: Re: Anybody know? in reply to galen, 01-30-2001 14:46:30
There are a few coil teeth left on the outside ends of the bars near the drive disks, so you're probably right about that. Thanks, Galen.
JD70Jim
01-30-2001 09:15:03
I think that IH made a model "35" and this could be one of them. All the IH rakes I've seen had more paint, but it looks like what I remember seeing.
jp
01-29-2001 22:32:25
You sure its an IH? It looks exactly like our old Ford rake. Every single part from the jack to the frame to the bars is the same. Don't remember the number of ours, but it is the same as the current NH 278 I believe.
Tim(nj)
01-30-2001 18:21:58
 Re: Re: Anybody know? in reply to jp, 01-29-2001 22:32:25
Ford sold an IH forage harvester painted blue at one time. Wouldn't surprise me if Ford also sold blue IH rakes.
Dick Davis
01-30-2001 06:43:19
can you post a picture from the side with more contrast? Looks like my neighbors but need more details to be sure. Dick Davis
F14...Also...
01-30-2001 12:36:57
 Re: Re: Re: Anybody know? in reply to Dick Davis, 01-30-2001 06:43:19
it IS a 5 bar, I just went down and checked. Rubber-mounted tines.
F14...Here ya go..
01-30-2001 08:04:03
third party image
Got some better shots this morning, sun wasn't glaring off the snow...
F14...Pretty Sure
01-30-2001 05:02:09
What paint there is is IH colors, and it has an IH serial number tag on it...":^)
shoguy
01-30-2001 05:07:46
 Re: Re: Re: Anybody know? in reply to F14...Pretty Sure, 01-30-2001 05:02:09
looks like a i.h. 3 bar i used 20yrs ago.Don't know the model,think it's still around sisters farm,i'll check.
Al
F14
01-30-2001 08:00:45
 Re: Re: Re: Re: Anybody know? in reply to shoguy, 01-30-2001 05:07:46
Thanks, this is at least a 4 bar, suspect it may even be five. Keep forgetting to count when I'm down there.
Tim(nj)
01-29-2001 20:19:25
It looks like a #15, but I don't remember if that one had chain drive or not.
