Hydraulic Question
Jim Vogel
01-31-2001 07:01:19
I have a Freeman front loader on my 3000 that uses a control valve mounted on top of the transmission. The lift cylinders are single acting, and i want to convert to dual acting, which requires a new control valve. The Ford dealer says I need a K1 valve kit, and it costs over $500. Is this the valve I need, and if so, does anyone know of a source where I can buy either a Ford or an aftermarket valve for a better price than this? I can email pictures of the valve if needed.
Thanks,
Jim
Taylor Lambert
01-31-2001 17:40:22
 Re: Hydraulic Question in reply to Jim Vogel, 01-31-2001 07:01:19
Yes northern sells one that has the float and all fixings round 179 bucks i think i put one on my neighbors old Dearborn Loader the other day 2000 psi relief i think. do you have a pump on the front of the motor?
Jim Vogel
02-01-2001 05:50:47
 Re: Re: Hydraulic Question in reply to Taylor Lambert, 01-31-2001 17:40:22
No, I am currently running off the tractor pump. It's pretty slow, but for what I do it's adequate. I am considering changing to some type of external pump, but am not sure how to do it. Any comments/suggestions?
Taylor Lambert
02-02-2001 13:39:16
 Re: Re: Re: Hydraulic Question in reply to Jim Vogel, 02-01-2001 05:50:47
Ive had good workings out of a side mounted belt drive pump. have maounted a lot on the front of the crank shaft to. but you have to make a guard for it.
