HAYRAKE QUESTION????
JDHUMP
01-31-2001 18:47:56
I have a sickle mower with a 6'cutting width, what width rake should I get, or doe's it matter? JDHUMP
B.C.
02-03-2001 13:09:59
 Re: HAYRAKE QUESTION???? in reply to JDHUMP, 01-31-2001 18:47:56
I used to worry about that until a neighbor showed me how to double windrow (up on one side, roll back the other way on the return trip). It really doesn't matter. Works fine.
JD70Jim
02-01-2001 11:06:43
Years ago we used to mow with an old JD #5 which was 7ft and raked with a JD #350 pto rake which was 7 ft. The rake was the same size as the swath. Then we bought a moco which was 9 ft. When we tried to rake the swath with the 7 ft rake. it left a foot of unraked hay. Understand that we were laying the hay flat and not windrowing it with the moco to get faster drying times. We upgraded to a JD 640 rake shortly after we got the moco and had no further problems. My $.10 worth.
Charlie
02-01-2001 06:31:58
I have a couple of the old horsedrawn hay rakes I use all the time to rake hay cut by a 9 ft haybine. They can get the full width but it wouldn't work if the swath was any wider.
It doesn't matter.
01-31-2001 18:51:27
After you cut it, you rake it into a windrow which is about 2' wide or double-windrow put two together as I often do to cut my number of passes with the baler in half. Any old rake will do fine.
JDHUMP
01-31-2001 20:18:49
 Re: Re: HAYRAKE QUESTION???? in reply to It doesn't matter., 01-31-2001 18:51:27
Thank You It Does'nt Matter JDHUMP
tommyw
02-01-2001 08:17:09
 Re: Re: Re: HAYRAKE QUESTION???? in reply to JDHUMP, 01-31-2001 20:18:49
we have a 9 foot cutter and a 7 foot rake,that doesent work good.with your cutter ANY rake will work. the most common size is 9 foot,they also come in right and left.
Phil
02-01-2001 10:59:22
 Re: Re: Re: Re: HAYRAKE QUESTION???? in reply to tommyw, 02-01-2001 08:17:09
Why doesn't your 7' rake work good with a 9' cutter? All of the mower/conditioners I've seen have angled shields on the exit side and the cut grass is put in a windrow smaller than the width of the cut. The ones I'm familiar with are adjustable so if you move each side in 1 1/2' than you windrow should be 6', small enough for a 7' rake.
If you have a 9' sickle mower that drops the grass than I can understand why it wouldn't work too good.
rhudson
02-02-2001 13:42:46
 Re: Re: Re: Re: Re: HAYRAKE QUESTION???? in reply to Phil, 02-01-2001 10:59:22
i cut hay with a newholland 1469 9' then use a 5 wheel rake. rake one windrow to center of the second. on the way back raked the third to the center. worked great . this year i used a pt-10 9' cutter and had to rake three trips instead of two to get the same result. its a bummer. for some reason i cannot get the pt-10 to windrow as narrow as the new holland. i still like the pt-10 because its made tough, but i will have to rethink the raking process.
