I must be cheap
Tyler(WA)
02-01-2001 09:50:51
I've been planning to make my own subsoiler to "plow in" some power and water line. It's easy enough to add a pipe down the backside of the shank and mount a spool to feed the wire/pipe.
I priced the steel from a local "Metal Supermarket" and found the $$$ went to $200 real fast. I thought "I oughta be able to just buy one already made for that" and found the price for a cheap one was about $195 and anything as strong as I was planning was well into the $300 range.
What should I expect from the used market? Do used subsoilers show up very often?
Dave in Mo
02-02-2001 09:14:12
 Re: I must be cheap in reply to Tyler(WA), 02-01-2001 09:50:51
Spend some of your Boeing Bonus money and get a good one. Their shanks are made of alloy steel, not like that low tensile stuff that you'll find at a steel yard. And besides that, it should have shear bolts on the weldments to protect your investment not to mention that even some have replaceable/reversible bits.
BFO
02-02-2001 11:23:15
 Re: Re: I must be cheap in reply to Dave in Mo, 02-02-2001 09:14:12
Most shanks are cut from structural steel plate or bar stock, except on the high HP spring resettable rippers. Shear bolting is simple, build one yourself, and save $$$.
Dave in Mo
02-02-2001 11:52:21
 Re: Re: Re: I must be cheap in reply to BFO, 02-02-2001 11:23:15
I made one out of structural steel too. It folded up like an accordian.
BFO
02-02-2001 11:58:20
 Re: Re: Re: Re: I must be cheap in reply to Dave in Mo, 02-02-2001 11:52:21
Well, don't waste your money on a Worksaver, it won't last for you either.
Tyler(WA) Follow up
02-01-2001 10:40:40
I found a steel yard that worked with me a bit and they helped me find lesser expensive material that would do the same job for me. Like welding two 3/4" plates to get my 1.5" share thickness. Some dimensions are radically more expensive than standard equally acceptable stock. If I go through their rather large pile of "drops" (end pieces from previous orders) I can get what I need for about $125.
bill b
02-01-2001 11:21:40
 Re: Re: I must be cheap in reply to Tyler(WA) Follow up, 02-01-2001 10:40:40
well if you are as cheap as i am you could try your local scrap iron /metals recycler dealer (junk yard ) and see what they have . i have found just what i was looking for there... of course they probably will charge a lot more than they paid but can still be a good deal..... .bill b
Not Junior
02-01-2001 17:15:31
 Re: Re: Re: I must be cheap in reply to bill b , 02-01-2001 11:21:40
Saving money is my favorite sport! At least for purposes of this forum.
