Dear Born (wood bros) combine
Jim F.
02-04-2001 17:21:47
have mod. 16-23A combine with wisconson air cooled need service manual and opperators manual as i am starting to bebuild any help would be apprecated. I am from AB. canada thanks jim f.
Greg
12-02-2003 09:28:21
 Re: Dear Born (wood bros) combine in reply to Jim F., 02-04-2001 17:21:47
I will look for manual when I get to the farm this winter. I spent many hours with this model combine.The biggest problem was when you shut the motor off without letting it run for a few minutes to cool it down. It will warp the valves and is impossible to re-start until it cools off. Also the valves will stick if you let it set for long periods. We made a tool to go inside the spark plug hole just to pop the valves loose. If you are using for different grains the RPM setting for the thrashing bar is critical.Finding canvas for elevators was tuff back in the 60's so you may have to make your own.I will get back with you if I find the manual but if you have questions I will try to answer
Greg
Leroy
02-04-2001 17:44:33
Tryed to email direct, don't think it worked, Have a manual I could copy for you for costs, 84 pages and shiping from Wapakoneta, Ohio U.S.A. If interested get with me.
