Sisal or plastic twine
agman
02-06-2001 15:39:28
Trying to determine wether to run sisal or plastic twine through baler. Bales stored inside so string rot is not a problem. Which is better for the baler knotters?
cs
02-08-2001 11:31:06
 Re: Sisal or plastic twine in reply to agman, 02-06-2001 15:39:28
Wait untill you see your cow dead with a piece of plastic twine hanging out her behind and the Vet just shakes his head.
david
02-07-2001 14:32:42
Three years ago I switched from sisal to plastic on a JD 336. I have seen drastic improvements in bale tying. The baler has the factory knotters, I made no adjustment, just put it in. Two real advantages storing inside, mice used to really damage my timothy hay twine, not so with plastic. The reason I switched was when I went with automatic bale wagons. The sisal just didn't take the abuse. BUT like the others said, it stays forever! Treat it like wire (I also use a wire baler). While you don't have hardware disease problems a piece always gets away and it will wrap around a cows foot.
bob
02-12-2001 13:20:27
 Re: Re: Sisal or plastic twine in reply to david, 02-07-2001 14:32:42
I don,t like some things about plastic but last two years have had trouble moving bales as twine rots or breaks This on round bales YEs i,m still picking up twine from ten years ago when boy fed Hes changed his mind now when he has to contend with it
JD70Jim
02-07-2001 11:20:26
We used to run a 14T John Deere. For 30 years it used sisal twine. When the old girl finally wore out completely, we traded for a 337 JD. The dealer had it set up for what they reccomended...plastic. An older baler apparently does not do well on plastic and newer ones like plastic better. I do know that the plastic has a uniform tensil strength. There are no weak spots in it like I used to find in sisal twine. The knotter may also work a little better on plastic. THE PLASTIC STUFF NEVER ROTS. You do have to pick up after yourself. Also, whenever we used to have a leftover bundle of sisal twine, it absorbed moisture or something over winter and the next spring, you threw it away and bought fresh twine. Plastic twine is good on the shelf for decades.
Tim(nj)
02-07-2001 18:57:51
 Re: Re: Sisal or plastic twine in reply to JD70Jim, 02-07-2001 11:20:26
My grandfather was successful in running plastic twine through a 14T from 1985 to 1990, when the old baler finally died of wear. The replacement 336 he bought (and I still use) has run nothing but plastic since 1990.
JD70Jim
02-07-2001 19:46:03
 Re: Re: Re: Sisal or plastic twine in reply to Tim(nj), 02-07-2001 18:57:51
Tim(nj): I kind of suspected that the 14t would run the stuff, especially since I was informed there is little if any difference in knotters from the 14t to the current 328/338/348 series. We always ran what we first used 35 years ago. As we ran sheep there were reasons for that too. I was informed that there is a set up procedure to adjust the baler for plastic (have no idea what that is). Our 14t did very well on sisal. The 337 which we got in 1995 has always used plastic and has performed even better than the 14t on it's best day.
Tim(nj)
02-07-2001 20:38:34
 Re: Re: Re: Re: Sisal or plastic twine in reply to JD70Jim, 02-07-2001 19:46:03
The tension at the twine box has to be adjusted differently for sisal and plastic. In the past, there were two different billhooks used in the knotter. One only worked with heavy sisal, the other was multi-purpose. The parts department only supplies the multipurpose now, and that's the one that works with the plastic twine. There may be some older balers out there that haven't had their billhooks updated yet.
rhudson
02-06-2001 20:03:35
plastic will never, never,,never go away. it will turn your pastures into a type of trash dump. it will be eaten by your cows it will wrap around their feet and cut into their hide. it will stop up your mowers it will wrap around spindles and rip out your seals. it will never, never, never go away. your grandchildren will curse and call you names for using it. by the way agman, i dont like plastic.
paul
02-06-2001 19:18:20
Plastic never goes away, so if you use it, be sure to pick up EVERY scrap of it when feeding. If you plan on selling any hay, make sure your buyers go for plastic. Sheep folks don't like it, gets into the wool.
--->Paul
MoosieDog
02-06-2001 19:18:08
FYI - We switched to plastic several years ago, when it first marketed. We will forever be sorry. If you feed the bales in the meadow or let the strings lay anywhere, they remain forever. I'll be quite happy if the day ever comes that I can mow a complete round without removing plastic twine from a clogged mower.
Charlie
02-06-2001 19:15:53
While plastic twine is better it depends on the baler you are using. Many older baler can't use plastic.
BB Butt
02-06-2001 16:12:42
sisal
