Clearing new land
Mike
02-12-2001 07:05:49
I am looking for info. on implements I can use with my 30 hp belarus # pt hitch that wii help prepare the soil for planting. The area was last farmed 30 years ago. It had a lot of small growth pines, oaks and brushy growth on it. mostly 3-4 inches in diameter, but a few larger trees and some old stumps ( the area burned about 7-10 years ago ) i brush hogged it last fall. What implements would be good to use to get the small roots out with my tractor- Ive been told a brush and bog disc could be used, but that they can make a mess if you dont know what you are doing. My tractor is 2 wd and I want to be safe. Also any advise for removing the larger stumps without hiring a dozer?
Shep
02-14-2001 21:21:55
 Re: clearing new land in reply to Mike, 02-12-2001 07:05:49
Mike -
I have been using my Oliver 550 for about 2yrs. now to clear 35 acre pine plantation. Talk about stumps, & still not done! Also can't find a used disk plow (turn ground) to save my soul; guess they went out of favor in the '40s. Had to buy a backhoe :)
Anyhow, since you are now not past the point of rtn I would suggest hiring a dozer operator. An experienced fella can do wonders in a short amount of time. Ask around and find someone with a good reputation (ask septic tank installers, county road maint, pond owners, mobile home installers, etc). Then go look at his some of his work and also check out his rig (no not riggin' LOL!).
Does he take of it? Does he do a good job of "finishing"? Down here in FL it runs about $55/hr but man the work they can do. Make sure you have a clear plan ready to leave with him and consider marking property with florenscent tape. Check progress daily.
I had a fella dig a 4 acre fish pond 12' deep with 4' beach & it took him only 5 days! Did a great job, buried trash in my drive for fill and he pushed most of the clean dirt where I wanted it.
bbott
02-12-2001 17:39:28
Mike, how much land do you have to clear and how big of a hurry are you in ?
If you're planting crops (not pasture) you need
to get those roots and stumps out, piled, dried and burned.
IMHO the only quick and safe way to do this is with rippers and a brush rake on a Cat.
The alternative is to pick away at it with your tractor with a ripping subsoiler or the aforementioned bog harrow.
If you do that I strongly advise having a ROPS.
If you hang up on a big root or ride over one, things could get exciting in a hurry. Keep your foot close to the clutch.
All above IMHO.
bbott
Mike
02-13-2001 07:38:12
 Re: Re: clearing new land in reply to bbott, 02-12-2001 17:39:28
Thank you for the reply. Im currently working on just about one acre and will start more clearing this next fall when the weather cools. What is ROPS? I am also unfamiliar with a ripping subsoiler. Thanks for the advise.
dick
02-13-2001 13:59:44
 Re: Re: Re: clearing new land in reply to Mike, 02-13-2001 07:38:12
ROPS stands for "rollover protection system". The concern here is that you are going to snag your implement on a root, or whatever, that's going to bring it (the implement) to a sudden stop. The tractor, being a very high-torque machine, will respond by immediately lifting its front wheels up in the air and flipping over on its back. Guess where you end up if this happens. This is a classic tractor accident, often fatal. Please try to avoid it. As bbot indicates, a Cat is really what you want for this sort of task.
A ripping subsoiler is basically a tooth-like implement an inch or two wide that sticks down into the ground a foot or so and rips out everything it encounters as the tractor moves along. Works great as long as you don't encounter something too tough for the tractor to handle.
