Ford 3pt grader blade
Ray,In
02-26-2001 08:22:10
I just bought this grader blade, and wonder when it was made etc. The ID tag reads: componet 19-205; serial no. 4029. there is no model no. This blade swivels both, horizontally and vertically, ie: you can turn both swivels to 45% and cut a ditch in a vee shape with one corner of the 6' blade. The implement is heavy enough you don't need to add weight, I'd guess near 400#
Brian Duffney
12-01-2006 06:39:59
 Re: Ford 3pt grader blade in reply to Ray,In, 02-26-2001 08:22:10
I have a series 716 FORD blade also, as fas as I can tell it was made in the mid to late 60's. starting in 1970 they implemented the 786 series blades. I guess your's is mid to late 50's.
John Miller, III
02-27-2001 20:58:27
I got a Ford rear blade a couple years ago at an auction. It's 8', 716 Series, 19 186 Components, with the same multiple adjustments. I was told it weighs about 750-800 lbs. w/ skid shoes.
It's very heavy duty, 5/16th's X 17" mouldboard, with cat 1 pins for adjustments. I'll bet yours is the brother to mine!
charlie
02-26-2001 19:37:30
i can't say for sure without seeing it,but it sounds like a servis rhino.
RayP (MI)
02-26-2001 17:46:52
Sorry, can't help you with the infro, but it sounds like a dandy! Keep it!
