Case seeddrill
mike jenezon
03-12-2001 22:00:46
I have an old case seed drill it drills 8' wide has galvinized boxes and is in overall good cond. annyone have ideas about its value thanks mike
HUBB
03-15-2001 11:02:27
 Re: case seeddrill in reply to mike jenezon, 03-12-2001 22:00:46
Mike - I have an old Case drill like yours, but I can't seem to lift the planting mechanism so it does not drag on ground when I transport it. There are two levers in centre on tractor side. Could you tell me if these are the two I should be using for raise lower and engage? Good luck selling yours.
mike jenezon
03-15-2001 19:07:14
 Re: Re: case seeddrill in reply to HUBB, 03-15-2001 11:02:27
if yours is the same the two levers in center are for raising the drill they have ropes hooked to them and you pull them as you are moving foward and it lifts the drill and disengages the feed for the hopper this needs to be greased and free to turn hope this helps if you need more info let me know and i'll be glad to help any way i can let me know the outcome mike mjenezon@cybernetisp.net
Daniel
03-13-2001 05:29:31
I bought one like yours for $30 at an action in
Southwestern Indiana two years ago.
Dick Davis
03-13-2001 05:16:33
Bought a 10' Case drill on good rubber & hydraulic cylinder overall excellent condition last spring for $ 300. Western Iowa, hope this helps. D-2
