Farmall Belly Blade for Super C
Steve K.
03-13-2001 13:15:47
I was woundering if anyone had any experience using a #72 Leveling and Grader blade on a Farmall Super C. It is raised and lowered by the cultivator lifts in the middle of the tractor. I am trying to decide whether to buy one of these or spend 2 times as much for an after market 3pt. and a back blade. Are they Heavy Duty enough? Thanks Steve K
Kenneth Cyr
07-31-2003 17:55:32
 Re: Farmall Belly Blade for Super C in reply to Steve K., 03-13-2001 13:15:47
Where would I be able to find the mid mount grader attachment? I have a Super C that I would like to put one on.
Taylor Lambert
03-15-2001 17:42:54
I have a front/mid mount grader for my Cub, in the Mid mount position it Grades better than the front it also mens less poivot because ti has no rear wheels in front of it to pivot on like a rear blade. The only down side is when you want to push a pile of dirt but i usually just catch the out side edge like the big graders do. Id invest the money in the mid mount blade.
george
03-14-2001 08:04:20
Steve:
I do not have any experience with a C, but I can tell you that a belly blade will grade better that a 3-pt. The 3-pt tends to ride-up when it encounters any resistance, since most 3-pt lifts do not have down pressure. The belly blades will average the grade better even without down pressure since they are being pushed rather than pulled (road grader).
Steve K.
03-15-2001 09:51:14
 Re: Re: Farmall Belly Blade for Super C in reply to george, 03-14-2001 08:04:20
Thanks for your response George!
It will be awhile, but when I do get one on the Super C, I will let you know how it works.
george
03-16-2001 07:09:39
 Re: Re: Re: Farmall Belly Blade for Super C in reply to Steve K., 03-15-2001 09:51:14
post some pics!
