Fast-hitch plow
Farmall43
03-20-2001 11:00:07
I have a 58' 340 with fast hitch. I am looking for a plow for it and would like your opinions on what set up would be best and how much to expect to pay. The tractor has loaded tires,wheel wheights on rear. And frame weights on front. The ground Here in mid MI varies frome clay to sand in my fields. Thanks in advance. Farmall43
redbarron
03-20-2001 19:41:16
 Re: Fast-hitch plow in reply to Farmall43, 03-20-2001 11:00:07
Hi Farmall 43 I also have a 58 Farmall 340 with fast hitch. I
pull a 3 bottom fast hitch plow with mine. If you
are going to buy a plow make sure you find a heavy
duty,there was some sold back in 58 with light
beams and did not plow real good in sod. I had one and traded for the heavy duty. It has a box
beam that runs diginal across the plow beams for
support,and does a great job of plowing in any
soil. We also have clay to sandy loom soil here in
western Pa. I have seen 3 botttom fast hitch plows
sold at auctions around here from $ 100 to $300.
It sounds like your 340 is set up ok for weights
all you need is the plow.Hope this helps.Good luck RB Ps Need any more info E- mail me
Alvin
03-20-2001 19:28:22
not more than 2-16's..
