Broke Sod Ground Need Help Smoothing
Tom
03-21-2001 16:01:51
I have broke some ground and more to do ,the disc is breaking it good but it is still rough and some clods ,used a leveling disc and a brillion cultipacker but still rough what about a good section harrow or spring tooth harrow or some kind of drag ,tiller would be good but too slow any help would be appreciated have to beat the next rain THANKS
Robert in W. Mi.
03-22-2001 15:09:11
 Re: Broke Sod Ground Need Help Smoothing in reply to Tom, 03-21-2001 16:01:51
By far the best way to deal with sod is with a Rotovator!!! Don't you believe those that say green sod can't be dealt with in the first year!! I custom Rotovate green sod all the time, and two trips over it, (a week or two apart)and it will look like it has been worked for years!! This is why many of my customers call me, and leave their plow, disc. ect. parked in a hedge row! Robert
david
03-22-2001 12:00:54
Arround here (in burley tobacco country) where we need a seed be suitable for transplaning we "slab" ground. After plowing in Feb. I like to wait until mid April thenpull a "drag" accross the field. Some people use 3 crossties bolted together, my dad uses guardrail sections 3 thick and bolted 3 long. I use a 12'x6" section of I beam bolted to two 6"x12' steel pipes filled with concrete. After slabbing we wait a couple of weeks and then disc with the same drag behind the disc.
paul
03-21-2001 19:26:45
Um, the rain will do it for you, don't know why you are trying to beat the rain?
Around here, the best is to plow in the fall, let winter & rain mellow out the soil over winter. But then, if you're doing field work now, you mustn't have much for winter! :)
--->Paul
Charlie
03-21-2001 18:27:42
If its sod from living grass you will never get it broken up very well the first year. It helps if you don't disk or drag very deep as it will turn up more sod. The best way is to kill the grass first, then plow. It also helps if you can plow sod early and let is sit a few weeks before working it. A good plowing job helps with sod as well.
