Bush Hog Vs. Landpride
Roy B
03-25-2001 08:45:33
Trying to deceide between a 6' Landpride series 25 or a medium duty Bush Hog rotary cutter. Both have 1/4" sides, 10 ga. tops, cat. 4 drivelines, similar rated gearboxes and 2" max cut. The Landpride weighs about 100 lbs. more than the Bush Hog. The finish of the Landpride seems a little better, but costs $450 more. Any thoughts or advice would be appreciated. Thanks. Roy
Martin
03-26-2001 07:48:46
 Re: Bush Hog Vs. Landpride in reply to Roy B, 03-25-2001 08:45:33
450 DOLLARS?! Sounds like a no brainer to me. If it were a $50 difference then I could see the dilemna. This is how it works on my budget anyway. They both sound like they are good quality, you can't go wrong I don't belive.
