IH #46 baler
PLOWBOY
04-01-2001 04:06:27
Went to a sale yesterday and bought IH #46 baler for $180.00 she's in real good shape,it baled last summer.All of the twine guides are nice and shinney on the knotter...I,ve been around,in,under,atop and BEHIND!@#$% a many balers but never owened one.I need to know the Do's and Dont's,tricks of the trade. where can I get oper.manual?
REM
04-11-2001 11:05:28
 Re: IH #46 baler in reply to PLOWBOY, 04-01-2001 04:06:27
Hi, The IH 45 and 46 have a reputation of eating PTO units. Be careful.
Tredd
04-06-2001 13:18:26
I been baling for the past two years with an 8N, a Bush Hog, a Ford rake, and an IH 46 baler. The one suggestion I have is if you have trouble with the baler knotting, don't do what I did and spend a year tweaking it. Hire someone to come out and within 10 minutes he’ll have knotting perfectly ( best $100 I ever spent ). The problem with mine was the timing was out on the disc on the left knotter causing it just to miss the knife. If you adjusted the knife to cut, the knot wouldn’t tie. Also, like the last guy said, dull knife blades will cause knots to pull out and a dull plunger blade will cause undo strain on the baler.
Enjoy, it’s a great baler and will last years with care.
Leroy
04-05-2001 18:32:07
Want a Photo copy of manual? If the slides on plunger get worn will not tie.
Charlie
04-01-2001 07:18:55
I use a model 46 for baling about 2000 bales per year and have owned it for about 13 years. Mine was in very good shape also when I got it. I got the set of manuals from Binder Books. I've only had 2 problems with mine. Once I had tying problems and it turned out the cutting knives were so dull it wouldn't cut the twine. I now sharpen them every year while getting the baler ready for the season. The other problem I had was one side was missing about every 30th bale. Using the manual I found out 3 of 4 springs that work the hay retainers were missing. I replaced them and it hardly ever misses a bale. I think its a very good baler.
