EXTEND vs primer on rusted impelements
David A
04-02-2001 08:54:26
I'm trying to decide whether to use Extend rust inhibitor or just plain primer before painting a heavily rusted implement. Plan to wire brush, prime (or extend) then brush paint.
What seems to work best, Extend or regular primer?
Thanks
VAC nut
04-04-2001 20:39:44
 Re: EXTEND vs primer on rusted impelements in reply to David A, 04-02-2001 08:54:26
You might try a product called Corroless from www.eastwoodcompany.com, or POR-15, either one of these products can be painted over rust after wire brushing the loose stuff off and then topcoated if you follow the directions.
David A
04-05-2001 04:13:11
 Re: Re: EXTEND vs primer on rusted impelements in reply to VAC nut, 04-04-2001 20:39:44
Thanks,
I'll look for one of these.
sammy the RED
04-02-2001 22:39:39
Have used both. Put the Extend on, then prime , then paint.
