3-point hitch
E . Singletary
04-04-2001 09:19:15
I have a 52 Mineapolis Moline model U. So far I am limited to pull behind implements because all it has is a kind of pivoting hitch bar. Is there an after market three point hitch available? Northern sells a 3 point quick hitch would it fit? How hard is it to use. My tractor also boils over after I have worked it hard. I was told this was normal- that it did not have a pressurized cooling system. I use my tractor and would like to expand its abilities.
Leroy
04-05-2001 18:03:02
 Re: 3-point hitch in reply to E . Singletary, 04-04-2001 09:19:15
I dont think a 3 point hitch can be put on used to have a U, If it boils you have major problems cloged radiator or block or bad water pump but boiling is not normal, corect that boiling befor you do any more damage than is already done.
Glenn
04-05-2001 04:38:34
You might try contacting Saginaw County Tractor Parts. They sell aftermarket 3-point hitches, but I don't know if they have a model that would work on your tractor.
9161 Sheridan Road
New Lothrop, Michigan 48460
(810) 638-5787>Link
There>Link are also some other companies that sell aftermarket 3-point hitches.
- Glenn
Tim(nj)
04-04-2001 20:59:23
You need to have a 3-point already on the tractor in order to use a quick-hitch. A quick-hitch is just an accessory to allow you to hook up 3-point equipment without getting off the tractor (theoretically, anyway).
